turbinesurgeon
- Oct 10, 2005
CrimsonEclipse said:I can fly'em and fix'em. If the 60k jumps considerably after the first
year, then take it.
CE
turbinesurgeon said:It doesn't jump much at all, it tops out about 80k
CrimsonEclipse said:Hmmm.... Your current position is bankrupt, if so, then take it. You can
always change jobs or directions in the future. It would also be an
interesting learning experience and you will likely work hard.
How will the QOL (quality of life) be?
CE
avbug said:That's not an unusual rate at all. Considering your're not typed, you're starting as a new F/O in the aircraft, and typically for a 20 series or 25 lear f/o you're looking at the thirty five thousand range. Bumping up to fifty to sixty isn't bad for a new F/O. On that type of equipment, you probably won't be doing a lot anyway with respect to maintenance.
I know a lot of Lear captains in older equipment that are making the sum you cited, and a lot of lear f/o's who are making considerably less.
I've turned wrenches and flown for much of my career...most always at the same time. Sometimes literally.
CUBMAN said:Is this job in Scottsdale, AZ by any chance?
Cub
