Ameriflight turbine time building
skyaddict
Any Ameriflight guys out there? Wondering what sort of time you build in the 99's. Have heard as low as 350 h /year as well as much higher. Thanks.
it just depends on your run. some runs are as little as 1.5 hrs per day, and some are as long as 4-5 hrs a day. 4-700 hrs a year is what you can reasonably expect in a 99.
jparks said:
Do they hire right into the BE99? I am sick of the airline life and want a change, but don't want to go fly a piston.
Yep, they do hire directly into the BE99. I believe turbine experience is required.
The Seattle base is quite senior for turbine aircraft. I don't think its too difficult to get a Chieftain out of Seattle but there does have to be an opening.
You got shocks and pegs......Lucky
