Trout
member?
- Feb 2, 2002
Capt. JD said:Do you have to start in a piston to get into the turbo-props? If you have no turbine time is it possible to get hired into a BE99, SA-227, BE-1900? If you can start in a turbo-prop, which ones do you get, BE99? Thanks...
Without any prior turbine time you would start in a piston.
