Aircraft Current
The FAA sanction guidance table calls for a certificate suspension between 30 and 90 days. But if part of the evidence was that you asked before doing it and decided, "Heck, I can handle that," they'd probably forget about the table.
Not quite, if there is more than one count the Judge can issue a judgment for more than the "recommended" sanction. If in this case I see: "91.13 Careless or reckless operation" in the background. That can really up the sanction. I have watched Judges rip the airman a new orifice before the judgement. Then ....BOOM...... Certificate and the time and dollars it took - go bye.....
Not quite,
Why "not quite?"
The FAA may impose sanctions above the normal ranges when the following circumstances, relating to factors b, d, e, and h of paragraph 4 are present: the violation is other than inadvertent the violator has a violation history, the violation involves a significant degree of hazard, or the violator has a poor compliance disposition.
Mark, after reading your post then mine, I think we are saying the same thing. The Judge can rule outside the "normal" sanction if they decide to. You posted the quote.
JAFI
