Airbus Admits Problem on 320!
"The feds should ground every A320 and get to the bottom of all of the nose gear and flap problems before innocent people are killed."
Just like they grounded the 737s after the rudder problems.
Park the A320s!!!
Sure..
The A320 has killed a LOT of people due to pure mechanical failure!
Lets see...
Hmmm..
Oh...
The only accidents have been due to human factors....
bummer!!!
Some of these deaths would have been avoided in the "human error" region had Airbus utilized soft limits in there fly-by-wire system. I'm amazed Airbus hasn't changed that design. It seems to have caused more problems than it's worth. Has anyone heard of anything positive happening because of this system?
How many accidents have been caused by HAVING soft limits?
Being able to stall? Over G? Overspeed?
Every system has its limitations...
Believe me... I'm not trying to blow smoke in anyone's a@@.
If you understand the flight control laws... and understand the interface between the human and the automation.... its proven itself very well.
There's the high profile crashing in to the trees...
And several automation accidents (human factors)..
But there are real benefits of being able to pull FULL back stick at anytime and know the airplane will not over g and will give you eventually a max alpha climb out. (EPGWS escape maneuver)
FWIW.....
Boeing chose soft limits and a yoke...
Airbus went joystick and hard limits...
Both work with there own limits and benefits.
Is it me or were the majority of the recent string of crashes 737's? There are a lot of 320's flying around every day too.
Seems like most of the harpooning of the 320 comes from folks who have NOT actually flown it. Let's hear from a few guys with substantial AB time.
"Some of these deaths would have been avoided in the "human error" region had Airbus utilized soft limits in there fly-by-wire system".
I am curious, which accidents are you referring to?
For your reading pleasure:
http://www.iasa.com.au/folders/Safety_Issues/others/Bilbao.html
http://aviation-safety.net/database/record.php?id=20010207-0
http://dnausers.d-n-a.net/dnetGOjg/260494.htm
http://catless.ncl.ac.uk/Risks/16.96.html#subj7
http://aviation-safety.net/database/record.php?id=20010320-0
http://aviation-safety.net/database/record.php?id=19940630-0
How many other software flaws are there? Can an engineer sitting at a desk really anticipate every single possible scenario that might occour in flight? Could even the world's best pilot do that? I think not. SOFT limits are necessary for FBW so that glitches may be over ridden.
That's why Airbus switched to soft limits in the 380.
I read those reports you posted, and I fail to see how the Airbus control laws contributed to any of those accidents.
Are you implying that if the airplane had let them stall, that somehow the accident would have had a different outcome?
Maybe you could quote a few small bites from those articles that point to the probable cause being "the design of the aircraft's computer control system".
From the very first one:
"However, according to first released findings of the Bilbao accident investigation, the ‘activity’ of this safety feature was a contributing factor in the event: the alpha-protection contradicted the desired pilots action"
"In the light of the accident occurring only four months ago, and the sometimes lengthy ‘normal’ timeframe for implementation of safety revisions after an accident, it appears to be of “amazing speed” how Airbus Industrie, - even in the absence of a final report, has already decided and performed a modification on the alpha- protection control laws. This was done in an approach “to increase the flight crew’s authority”, - as Cpt. Brandt was quoted saying by media. - A step applauded even by staunch Airbus critics among the international pilot community. A revised software version is expected to be validated this month and has already received certification by the French Civil Aviation Authority (DGAC) and the European Joint Aviation Authority (JAA). Airbus plans to implement a “rapid retrofit program” for its entire A319/320 fleet."
Either you didn't really read them or your love for the scarebus blinded you, either way I ask the same question: How many more undiscovered software problems are there? Odds are there are many more. The computer is only as good as the human engineer that does the programming and nobody can think of everything.
The report you just mentioned is the report I was referring to in my post. If the airplane had let them stall, would that have been better?
I just can't think of any reasons why I would ever need to exceed the protections of the airplane, i.e. stall. The only time I can think of would be when there is an instrumentation problem, at which time the flight control laws degrade and the protections become stabilities, or soft limits.
Either you didn't really read them or your love for the scarebus blinded you, either way I ask the same question: How many more undiscovered software problems are there? Odds are there are many more. The computer is only as good as the human engineer that does the programming and nobody can think of everything. [/QUOTE]
Question answered by an unqualified person.
Metro752 said:
You're comparing a World War TWO Boeing B-17 to a "state of the art" Airbus 300-###
lol.....mmmmmmmmmmmmmmmmmmmmmmk
Not really, just the fact that they both will break their vertical stabilizers off if you apply full and abrupt rudder in one direction and then suddenly the other direction, even at speeds below Maneuvering speed. The FAA simply does not require airliners to withstand this sort of rudder application in order to be certified.
The 'state of the art' (not) A300 wasn't certified to withstand the stress of a fully deflected rudder one way and then the other because the FAA didn't require it. They darn sure should have required it though.
I'm not trying to bash AA, I'd love to work there, but I was in class with a now extinct airline and we watched an AA video on escaping wake turbulence and unusual attitudes. The instructor promoted pretty aggressive maneuvering, including uncoordinated use of rudder to raise the nose in a banked, nose low situation and to lower the nose in a banked, nose high situation. First time I'd heard that advice, my current airline teaches coordinated wings level, then pitch recovery. Did the NTSB recommend any changes to AA's training program after 587?
Even Airbus' own test pilots have crashed the electric Airbus. Twice. Both times due to confusion with the automation and flight control laws. So obviously it's a very complex aircraft. Kudos to North American Pilots who have a much better record that the rest of the world, in that they haven't crashed one yet.
Back to the original broadcast. A friend/CA, with whom which we landed a CRJ200 with disonnected nosewheel steering, asked an A320 friend if if had a nosewheel centering device in the event the scissors (torque links) aren't connected. Answer: no. Does the CRJ? Yes, he asked maint after our adventure, it isn't in our books. Ramp connected our scissors but the pins didn't engage in the holes, just rubbed the sides. Nosewheel steering worked until TO, the strut extended as we broke ground and the torque link came apart. Gear unsafe warn msgs (nose gr down, mains retracted) and WOW input fail caution msgs. QRH: manual gr ext, land. After an hour to make our ldg wt we saw 9R lit up like xmas with the trucks. Ldg was fine, nosewheel rattled a little, pax clapped, then at about 40 kts "BAM BAM BAM BAM BAM . . ." Nosewheel was skidding, jumping, skipping, skittering, and doing the shopping cart wheel dance, I believe the banging was from the strut bottoming out or the scissors hitting something. CA stopped the plane with more brake pressure and we got towed in eventually.
The Iberia Bilbao accident had nothing to do with letting them stall the aircraft, nor was a stall imminent. The stall protection logic MALFUNCTIONED and did not allow them to perform a go around/windshear escape manuver when it was necessary.
If there was nothing wrong with the software/logic why did Airbus revise the control logic?
The accident above is a good reason, they were lucky that it didn't end up much worse.
Here's another: Say you're in an A318/19/20 and the wake of the great white elephant A380 rolls you on your back. Who's flying the airplane? And what exactly is HAL9000 doing to recover? Are you comfortable with that? I'm not.
Given the large number of scenarios that don't involve the aircraft automatically reverting to soft limits, are you willing to bet your life (and your passengers) that the engineer thought of everything?
Please stop, you have no idea what you are talking about. The pilot has full authority to recover from an upset. Go to ground school or read a manual before you attempt to ground the fleet. Sounds like you really work for CNN.
Hey Superfluff,
Without going into a lenghty technical explanation, the 320 has certain flight "laws" that are part of the flight control logic. One of those "laws" is specifically designed for the exact problem of an inflight upset, like wake turbulence, so that the protections are inhibited and the pilot can take control and right the aircraft. As to the Paris Airshow crash of the 320, the test pilot pulled circuit breakers of the flight computers to prevent the logic during a low pass, thus inhibiting the protections built in. I think he's still serving time in a French prison for killing the boy who was a passenger during that flight.
Regardless, if it's built and maintained by man, there's still a possibility of human error, no matter who the aircraft manufacturer is.
