Age Limit
Herkenstein said:
Must be no older than 30 at the start of UPT
With that being said, since I'm 28.5, and many guys are scheduled for UPT in 07, should I even bother? I'll be pushing it. I'm in the very beginning of the whole process - I haven't even taken the AFOQT yet.
Thanks for your help!
I'll be 28 in a couple weeks and will be meeting the September rated-only board. You can apply at 29 providing you've got a PPL and a Flying Class 1 physical complete. As stated above you have to be in UPT prior to turning 30. You can turn 30 the day after it starts, but you gotta enter prior to.
You need the AFOQT, BAT, 5 letters of recommendation, and if you're meeting the board at 29 you need a FC1 physical, otherwise just a MEPS physical.
You could still make it, but you are definitely running out of time. Take the AFOQT & BAT asap, get your forms/resume started, and get your physical done. If you are selected on the next board, you should be ready for a no-notice class date for OTS.
The MEPS physical (aka DODMERB) is a basic qualification for military service. It is required prior to enlistment or commissioning. The IFC physical (initial flight class I for pilots) is more involved and qualifies you for flight duties.
Good luck
There is a waiver for everything...
See title.
One guy in my class was 35. Of course, this was close to 8 years ago, so YMMV.
Don't take no for an answer.
Jason
Mongoose69 said:
See title.
Jason
When I was a Tweet IP, I did see some older trainees, but the ones I saw were Air National Guard Navigators on the KC-135 who received age waivers to go to Pilot Training. This was granted due to the Pacer Craig (FMS Installation) Mod to the KC-135 and the phasing out of KC-135 Navigators. In general, everything Jafar said is right on.
If you're looking for Active Duty, contact your local OFFICER recruiter at www.airforce.com and follow the locator link. In a perfect world, this is your best point of contact, but since time is really tight for you, PM me if you have any questions, because I do help the OTS Recruiter in the PA/WV/OH area. He's a good guy and can answer what you're asking about.
