The limitation must be in the type certificate data sheet. If it is the maintenance manual, it is only a recommedation, if the aircraft is operated in Part 91. If your aircraft is on an approved maintenance program, follow the requirements of your program. If your program follows the manufacturers recommendations, that what you do.Any limitations set forth by manufacturer airworthiness limitations will be binding, or as established by AD.
