ImbracableCrunk
Unregistered Un-User
- Feb 5, 2003
I've already found several and I've only read the first two chapters. For example, on page 17 he says that high speeds affect the center of gravity.
The dutch roll explanation is just wrong... I don't own the book, but someone who I was flying with had it. I can't qoute the actual wording, but it was just wrong.
Sounds like an Embry Ridlle dorm on Friday night...
If you really want to learn it correctly LEAVE THIS BOOK ALONE!! Get your hands on 'Handling the big jets'. Can be costly but worth every penny.
How about multiplying the factors in the lift equation instead of summing them?
pg 149 "HUGS allows Cat III instrument landing system (ILS) landings only on runways certified for Cat I landings."
HGS gives Cat II mins on Cat I, correct?
6.2 Operational Benefits
Day-to-day operational benefits include the following:
6.2.1 Improved CAT I minima
Lower Cat I Minima can be achieved for aircraft equipped with HGS, irrespective of the nature of the facilities at the airport. In all cases, HGS gives direct and quantifiable operating benefits:
Type of Facility RVR without HGS RVR with HGS Full 550m 450m Intermediate 700m 500m Basic 800m 600m None 1000m 700m Table 1: Improvements in RVR achievable with HGS
6.2.2 Cat II operations on Cat I runways
Head Up Guidance enables Cat II operations to take place on CAT I runways, providing the following improvements are also carried out at the airport:
A review of the Airport ILS installation, requiring:
- a solid state transmitter
- tighter monitoring tolerances
- a 2nd IRVR Transmissometer in the rollout zone
- Beam protection zones enforced
- Type II obstacle clearance requirements are met. This necessarily implies that approval to operate in these conditions must be given on an airport-by-airport basis.
6.2.3 Improved Cat III Operations
HGS is certified for Manual Cat IIIa Approach and Landing Capability with a decision height of 50ft. and 200M RVR. It is also certified for low-visibility take-off, allowing operations down to 75M RVR. This means those early morning flights on foggy days will get off on time, allowing the company to maintains its schedule throughout the day. There is also the potential for Cat IIIb operations via the 'Hybrid' or 'Super Fail Passive' method. In this approach, the pilot utilizes the fail-passive Cat IIIa autoland and the HGS to monitor the performance of the autoland for approaches down to 150M RVR.
That book is full of errors. The author and publisher should be beat. "Handling the Big Jets" is much better and that IS the book Cathay gets their questions from. If you just want a book with questions though, I would suggest "Questions, Questions" from Air Inc.
Handling the Big Jets is a great book. It's just too bad they haven't updated it since the 70's ( . . . the upcoming SSTs . . .).
I don't suppose you'd like to add to the list? I'm almost done compiling the list I've got so far.
