I interned at AA, while i was there we were told an average year retired about 150 or so pilots. Between 2004-2007 they were projecting to lose like 450 pilots a year. That would help create some movement in the industry, unless AA just gets smaller over time.
I'm sure someone else could shed some light on this.
Your numbers for 2003 don't jive with the ones on AApilots.com. AApilots only shows 60 total retirements for '03. I like your number a lot more, 60 won't even make a dent! In fact, your numbers must be more current because TWA has more than 18 retirements next year.
Here's the numbers from AApilots, with the exception of 2003, our numbers are only a couple off of each other. Bottom line is that retirements at AA won't affect recalls / hiring for a few years because of all the fleet / capacity reductions.
Interesting, I wonder if those numbers were have supposed to included the Ferbs. Will check into it. As for impacting layoffs, I never thought they would. Only the economy will fix that.
Thanks for putting your stats down. Oddly enough I received mine from ask and answer on aapilots.com.
