A380 Landing
TXGold
Just made its first landing. Looks like the guy should've left the autopilot on until 50' AGL. It seemed to me there were some pretty big control movements going on. Anybody have an idea what the wind was in London at time of arrival?
I think it made a few landings before when it went on a tour of Asia a few months ago. This was its first time in London, though.
I noticed that too, there was quite a bit of rudder movement right before touchdown and the landing looked pretty hard.
Looks like a good amount xwind?
Iceman21 said:
I would be that they were very light and had enough fuel onboard to divert the to nearest place that could "handle" the plane. If something did go wrong on landing at heathrow, I'd imagine they didn't want to have a massive post crash fire.
What are you talking about?
Remember that all aircraft are making small adjustments when lining up for center line, they are just not as noticeable in smaller aircraft. But in the a380 these movements are magnified because of the sheer size of the aircraft. The longer the wingspan, the more the wingtips will appear to fluctuate as adjustments are made.
The heaviest plane I've ever landed only weighed a little under 30,000lbs, so that doesn't really make me qualified to comment.
On the other hand, I always consider an arrival to have TWO landings, the mains, and then the other wheel(s), be it in back or in front of the mains. In the case of larger aircraft, if the first landing is botched (the mains), there is some personal satisfaction in landing the nose wheels smoothly.
That being said, any true pilot of a large aircraft will take much greater satisfaction in a well flown, stabilized approuch over a smooth touchdown everyday. The public doesn't see it that way.
In the case of the A-380 the "second" landing looked a little jarring. The airplane movements also looked like they involved considerable inertia on all three axis. I wonder if that will be a negative attribute to this design. Have there been any public comments on the flight charactoristics of this plane by someone who has flown it?
Lilah
PS> In my half dozen 777 sim landings, I had three tailstrikes. It came from being conditioned to pull full aft yoke after landing on a particular taildragger.
The biggest Airbus I've flown is the A-320, but if the ultra-whale has the same flight control laws that its smaller sibling has, then crosswind landings will be a pain in the butt. I couldn't see much out of the ordinary in the small-screen video from the BBC, but it appeared to handle about like the 320 did as all the fancy flight-envelope protection laws were blended out at 50 feet to direct-law control, and your previously stable approach gets all squirly and shot to heck.
Then again, maybe the pilot was just having crappy day. Remember the old adage:
One smooth landing is skill.
Two in a row is luck.
Three in a row and someone is lying.
HAL
"The new pier 6 has been specially designed to handle the A380's twin decks."
Anybody heard the specifics yet on how they have designed certain gates to accommodate the 380? I bet if it parked at a normal gate, it would take forever to board.
I bet they board 1:20 min prior to blast off. Whose gonna wanna be sitting in 92E for that time frame before you even get moving? The question of alternates is interesting though. If it cant land at airoprt X, I am sure that it is severely limited in where it can divert to as a result of it's weight and specifically what airports and what runways and ramps can accomodate it. Lets see, if it's going to ORD, and the wx is down, I suppose it will have to use SFO or LAX as it's alternate.
If an a380 was sitting right next to a nice new B-787 (when it comes out), I would much rather ride on the 787.
Anyone know where to find the takeoff and landing distances? The idea of alternates is quite interesting. Also, am I right in assuming that the larger the plane the higher the cross wind that it can handle? If so then it should be harder for this plane to get Wx'ed out of an airport right?
HAL
HAL,
I would second those thoughts. When I flew the bus I never used A/T for the approach and landing unless it was an autoland. The thrust movements from A/T and the die-by-wire flight path unstablizer logic that the POS has made it a real peach in x-winds. When I saw the video it looked just like a normal bus landing in a big wind.
The issue of max crosswind component is not a matter of size, but more a matter of aerodymanics. True, most larger aircraft have a higher max x-wind component, but it not that much higher than many of the piston airplanes that are flown. For example, IIRC, the max x-wind on a MD-11 is 24kts.
AdamKooper said:
The bigger the airplane, the bigger the penis of the pilot. These pilots must be like horses.
It's the other way around...:)
CE
I was looking at the pitch adjustments being made and it seemed on the small screen to be pretty significant. Also looked like once he had the mains down, he was in a definite hurry to get the nose on the ground.
The heaviest machine that I`ve landed was about 380,000 pounds. Having said that, the approach and touchdown as seen on that BBC video looked about right to me. The pilot was doing a bit on pumping the stick down the final, but nothing that far out of the ordinary. I suspect that (1) it was a windy day and (2) he was at a fairly light (for the 380) weight. I`m just an old retired airline pilot and certainly no aeronautical engineer, so does anyone have an idea at to why this plane has such a monsterous vertical tail? It seems about one third too large. I`m sure the Froggies that designed it know what they are doing, but it really seems outsized to me. BTW iceman, the MD 11 doesn`t have much rudder, that`s why the low cross wind number.
My guess is to increase directional control if 2 engines go out on 1 side of the plane (those are massive engines).
That is jsut my guess...that depends on a lot of things that none of us know though.
