A question for the military guys.
Yes.
After furlough from UAL, I went straight to Military Leave. I flew to ORD (on NRSA), was fingerprinted, etc and received my Crew Badge. I was also entered in CASS. I flew home as an OMC in the jumpseat.
No problems on multiple airlines.
I would guess you get full non-revenue, space-A privileges with your carrier.
I don't think all airlines give you credit for time you are away on mil leave. I might be wrong but in some cases, if you went on mil leave the day after you were hired and came back a year later, I THINK you might still be on first year pay. Not returning to second year pay.
I know for sure at many airlines you'd still be on probation. I remember at UAL, dropping days for mil leave extended my probation by several months.
The probation thing muddies the water somewhat, but I believe you're still entitled to longevity for pay purposes.
Remember, the military member is the "victim".
Refer to Title 38 U.S. Code (USERRA):
http://www.dol.gov/vets/usc/vpl/usc38.htm#sub2
4313. Reemployment positions
(a) Subject to subsection (b) (in the case of any employee) and sections 4314 and 4315 (in the case of an employee of the Federal Government), a person entitled to reemployment under section 4312, upon completion of a period of service in the uniformed services, shall be promptly reemployed in a position of employment in accordance with the following order of priority:
(1) Except as provided in paragraphs (3) and (4), in the case of a person whose period of service in the uniformed services was for less than 91 days--
(A) in the position of employment in which the person would have been employed if the continuous employment of such person with the employer had not been interrupted by such service, the duties of which the person is qualified to perform; or
(B) in the position of employment in which the person was employed on the date of the commencement of the service in the uniformed services, only if the person is not qualified to perform the duties of the position referred to in subparagraph (A) after reasonable efforts by the employer to qualify the person.
(2) Except as provided in paragraphs (3) and (4), in the case of a person whose period of service in the uniformed services was for more than 90 days--
(A) in the position of employment in which the person would have been employed if the continuous employment of such person with the employer had not been interrupted by such service, or a position of like seniority, status and pay, the duties of which the person is qualified to perform; or
(B) in the position of employment in which the person was employed on the date of the commencement of the service in the uniformed services, or a position of like seniority, status and pay, the duties of which the person is qualified to perform, only if the person is not qualified to perform the duties of a position referred to in subparagraph (A) after reasonable efforts by the employer to qualify the person.
(3) In the case of a person who has a disability incurred in, or aggravated during, such service, and who (after reasonable efforts by the employer to accommodate the disability) is not qualified due to such disability to be employed in the position of employment in which the person would have been employed if the continuous employment of such person with the employer had not been interrupted by such service--
(A) in any other position which is equivalent in seniority, status, and pay, the duties of which the person is qualified to perform or would become qualified to perform with reasonable efforts by the employer; or
(B) if not employed under subparagraph (A), in a position which is the nearest approximation to a position referred to in subparagraph (A) in terms of seniority, status, and pay consistent with circumstances of such person's case.
(4) In the case of a person who (A) is not qualified to be employed in (I) the position of employment in which the person would have been employed if the continuous employment of such person with the employer had not been interrupted by such service, or (ii) in the position of employment in which such person was employed on the date of the commencement of the service in the uniform services for any reason (other than disability incurred in, or aggravated during, service in the uniformed services), and (B) cannot become qualified with reasonable efforts by the employer, in any other position which is the nearest approximation to a position referred to first in clause (A)(I) and then in clause (A)(ii) which such person is qualified to perform, with full seniority.
(b)(1) If two or more persons are entitled to reemployment under section 4312 in the same position of employment and more than one of them has reported for such reemployment, the person who left the position first shall have the prior right to reemployment in that position.
(2) Any person entitled to reemployment under section 4312 who is not reemployed in a position of employment by reason of paragraph (1) shall be entitled to be reemployed as follows:
(A) Except as provided in subparagraph (B), in any other position of employment referred to in subsection (a)(1) or (a)(2), as the case may be (in the order of priority set out in the applicable subsection), that provides a similar status and pay to a position of employment referred to in paragraph (1) of this subsection, consistent with the circumstances of such person's case, with full seniority.
Depends on the contract. NWA counts mil leave for probationary time and longevity pay.
That's nice. Sounds like a no-brainer if that's where your friend is heading.
At SWA, you lose pass privileges while on extended mil leave above 29 days I think (they actually want your ID back if you can believe that)
At CAL, pass privileges are good for either 2 or 3 years, while on mil leave, but you are taken off the active flyer's list, which takes you out of CASS, so no jumpseat. Seniority accrues and you still get B fund contributions. You can keep the health insurance for 1 year if you want. Probation does get extended....most of the time.
At Trans States they take your ID. No jumpseat or pass privileges. Oh well, didn't really need it in Iraq. BTW, the law is pretty clear that when you return from mil leave your status has to be the same as if you had never left.
My buddy went on mil leave for about 5 months during his first year (schoolhouse training)...kept his ID and jumpseated a few times as well.
I was able to keep my ID and pass privileges during my MIL leave (a few months). There are a few other pilots I know (one for sure) that was able to get a new ID because their ID expired while on leave.
Now, I will say, the company policy (what I was given) is a little ambigious with MIL leave. A lot is outdated with respect to USERRA it seems. We'll see what the future holds.
At SkyWest I was able to keep my travel/jumpseat privileges during 4 months of MIL leave. I talked to my CP and was able to pick up a trip here and there while on MIL leave as well
