they are 8 blades
The Navy is slowly phasing in the 8 blade props on the E-2Cs. All should be converted in the next couple years or so. C-2s are supposed to be getting them in the next 2-3 (who knows) years.
I haven't flown 8 blades but there are several pros/cons:
pros:
quieter, less vibration(on the airframe/equipment - less wear), a little more SHP, Virtually impossible to pitchlock (no pitchlock situations since the 8 blade can feather no problem with loss of hyd oil pressure)
cons:
when you pull the power back to flt idle, I have heard the airplane just doesn't want to slow down. Floats quite a bit. I have heard rumors that they might be installing speed brakes to counter this tendancy. There are a few other bugs with the system that are being worked out.
