2 in 1 seat, the double belt rule.
pilotviolin
God, your sky is so big;
I always heard that you could double belt kids in one seat if they were under a certain weight. ONLY Part 91. I was just shown that this is true. Search AOPA, they had it on their website. So my question is, what defines children? Up to what age do they consider someone a child. I read if the two kids together wiegh less than 170 lbs, it is ok.
Please don't responed with you personal thoughts on safety or what the airlines do ect... Lets stick to the Facts and FARS. Thanks
I'd say if the AOPA web site says you can do it, that would be the logical place to look for the conditions.
How about a link to the AOPA document?
I would like to see how that is done legaly. The basic reg says:
91.107 Use of safety belts, shoulder harnesses, and child restraint systems.
(a) Unless otherwise authorized by the Administrator—
(3) Except as provided in this paragraph, each person on board a U.S.-registered civil aircraft … must occupy an approved seat or berth with a safety belt and, if installed, shoulder harness, properly secured about him or her during movement on the surface, takeoff, and landing.
I did not find any part that said you could put more than one person in a seat belt.
JAFI
JAFI said:
I would like to see how that is done legally.
Interestingly enough, JAFI, there actually is an 1990 FAA Legal opinion that specifically says that you can use one seat belt around two individuals so long as weight and balance limits are not exceeded and the strength of the seat belt is not affected. I came across it doing some research for a friend.
it's below. Bear in mind that I have some questions about it, which is why I was asking about the AOPA link pilotviolin referred to in his original post.
Some of the questions are:
1. The opinion refers to 91.205(b)(12) as the seatbelt rule. In the current version it's 205(b)(13) which says "An approved safety belt with an approved metal-to-metal latching device for each occupant 2 years of age or older." I don't know whether the "(b)(12)" is a typo or whether, if it was moved, it was also reworded. Without comparing the regs before and after the date of the opinion, can't tell whether the opinion is still good or not. Which makes me wonder since
2. FAA Legal doesn't have the Opinion in it's on-line database, which does go back far enough to include it. Was that intentional?
3. That language in the third paragraph essentially says that it's "legal but dangerous." Sounds like an invitation to a 91.13 violation or a lawsuit if someone gets hurt.
4. It doesn't answer another question - some aircraft are specifcally certified for no more than 4 persons on board.
November 5, 1990
Ms. Kathleen Brockman
Aviation Specialist
Aircraft Owners and Pilots Association
421 Aviation Way
Frederick, Maryland 21701-4798
Dear Ms. Brockman:
We are responding to your request for clarification of a wording change in Federal Aviation Regulation (FAR) Section 91.205(b)(12) and whether that change affects the carriage of two children in one seat belt.
The July 15, 1986, letter you attached is an interpretation of then FAR Section 91.14, now FAR Section 91.107. The Federal Aviation Administration (FAA) policy is that the FAA does not require separate seats or separate safety belts for FAR Part 91 operations. One safety belt may be fastened around two individuals provided that the strength of the safety belt is not compromised and that the aircraft's weight and balance remain within limits. This policy is based on the Preamble to Amendment 91-89, effective in August 1971, and has not been superseded by succeeding amendments.
The change in wording of FAR Section 91.205(b)(12) reflects the current airworthiness requirements for newly manufactured, normal, utility, or acrobatic category aircraft. The change in wording does not affect the FAA's along-standing policy concerning bench seats and safety be1ts enclosing two individuals, as stated above. However, to quote from our 1986 letter, "...Experience has shown that the use of one seat belt by one occupant affords less of a chance of injury, in case of an accident, as opposed to multiple occupants using one seat belt. .."
You also asked what effect would shoulder harnesses for the rear seats have on our answer. FAR Section 91.107(b) states that, except for an airship or free balloon, each person on board a U.S. registered civilian aircraft must occupy an approved seat or berth with a safety belt and shoulder harness, if installed, fastened about the person. (Emphasis added.) If shoulder harnesses are installed on rear seats, they must be used, and this could preclude fastening one seat belt, with shoulder harness attached, about two persons.
The typical shoulder harness installed in normal or utility category aircraft is designed to provide upper body restraint for one person. Extending the shoulder harness across two people, especially children, would seriously detract from its safety purpose and could pose a safety hazard if a shoulder harness extended in this manner rests across the throat of one or both of the two persons.
If the shoulder harness is the type that can be detached from the seat belt, detaching it would not be allowed, since FAR Section 91.107 requires that if shoulder harnesses are installed, they must be used.
We trust that this has answered your questions in a manner that clarifies FAA policy.
Sincerely,
Gabriel D. Bruno
Manager, Operations Branch
Midlife, thanks for the reference. I am sitting here shakeing my head at Mr. Bruno's reply. First I do not know who this Mr. Bruno is and the letter does not say he is with FAA legal but let's assume he is for now. When the regulation states "for each person" I cannot see how he can say it is legal to have two children in one seat belt. Also, be careful when an interpitation is over 10 years old and the regulation text or number has changed. It could void the interpitation.
But I am not an attorney, nor did I stay at a Holiday Inn Express last night. And this would not be the only time our Legal Department caused me to roll my eyes and ask "what planet are you from?"
But IF that is the guidance, I will follow until changed or removed..........
JAFI
JAFI
I'd take this letter with a grain of salt as FAA Legal's fingerprints are nowhere to be found on it. Gabe Bruno was a FAA Operations Inspector and was the Manager of the General Aviation Operations Branch at FAA HQ when the letter was written. I believe he retired from one of the Southern Region FSDOs a few years ago.
He's not. I have a graphic that shows the original stationery. My bad in referring to it as a "Legal" opinion.
What about airplanes like the PA-12 Super Cruiser that have a large backseat and an oversized belt that were even ADVERTISED as being a "3 person airplane"?
midlifeflyer said:
i3. That language in the third paragraph essentially says that it's "legal but dangerous." Sounds like an invitation to a 91.13 violation or a lawsuit if someone gets hurt.
I would NEVER count on an FAA legal interpetation to mitigate exposure to a potential 91.13 violation.
Remember, it's just that. An interpetation. The FAA can and likely would violate you with injuries arising from something like this. And I can say with reasonable certainty that when you're standing in front of an ALJ, s/he could give a rats crapper about some FAA legal interpetation.
