135.385 Landing Distance
starcheckdriver
There has been a lot of discussion in other threads regarding FAR 135.285 and the 60%/80% rules for landing distances. Some say it is for planning purposes only and that you can land on a shorter runway meeting only actual landing distance numbers. It was my understanding from 135 training that you must have the factored distance built in on your landing runway and cannot land on a shorter runway that doesn't meet the 60%/80% runway requirement.
What does everyone think/do in their operation? Do they use it for planning only? Or, do you abide by upon arrival, even it means landing on a less favorable runway for wind purposes?
Far 135.385
I took the following from the FAA's Aviation Safety Inspector Handbook (Operations), FAA Order 8400.10 ...
LANDING FIELD LENGTH REQUIREMENTS
FAA Order 8400.10, CHG 5, (6/30/91) Volume IV, Chapter 3, Section I – Airplane Performance Computation Rules
/S/ 909 SMALL AIRPLANE CERTIFICATION.
E. Application of Flight Handbook Performance Limits. Many of the requirements of Subparts I of part 121 and Part 135 apply only until the aircraft takes off from the departure point. Other requirements from these Subparts apply at all times as do the AFM limitations. For example, FAR 121.195 and FAR 135.385 prohibit a large, turbine airplane from takeoff unless, allowing for en route fuel burn, the airplane will be capable of landing on 60% of the available runway at the planned destination. The regulations do not, however, prohibit the airplane from landing at the destination when, upon arrival, conditions have changed and more than 60% of the runway is required. In this case, the airplane must only be able to land on the effective runway length as shown in the flight manual performance data.
/S/ 921. WATER AND CONTAMINATION OF RUNWAYS. AFM performance data is based on a dry runway. When a runway is contaminated by water, snow, or ice, charter AFM performance values will not be obtained. Manufacturers typically provide guidance material to operators so that appropriate corrections for these conditions may be applied to performance calculations. Inspectors should be aware of the following guidance concerning these conditions.
A. Any runway which is not dry is considered to be wet. Standing water, puddles, or continuous rain are not necessary for a runway to be considered wet. Runway braking friction can change when there is a light drizzle. In some cases, even dew or frost which changes the color or a runway will result in a significant change in runway friction. The wet-to-dry stopping distance ratio on a well-maintained, grooved, wet runway is usually around 1.15 to 1. On a runway where the grooves are not maintained and rubber deposits are heavy, the stopping distance ratio could be as high as 1.9 to 1. On un-grooved runways, the stopping distance ratio is usually about 2 to 1. In the case of a runway with new pavement or where rubber deposits are present, the ration could be as high as 4 to 1. Some newly-surfaced asphalt runway surfaces can be extremely slippery when only slightly wet.
/S/ 933. LANDING DISTANCE. The maximum weight for an airplane landing on any runway must be limited so that the landing distance required by the performance rules will be less than the effective landing length available.
A. Effective Landing Runway Length. Effective landing runway lenght for all categories of airplanes is the distance from the point on the approach end of the runway at which the obstruction plane intersects the runway to the roll-out end of the runway. [read as “Threshold”, not glide slope intersect, ed.] The obstruction plane is a plane that is tangent to the controlling obstruction in the obstruction clearance area that slopes down toward the runway at a 1:20 slope from the horizontal. The area in which the obstruction clearance plane must clear all obstacles is 200 feet on each side of the runway centerline at the touchdown point, which expands to a width of 500 feet on each side at a point 1.500 feet from the touchdown end and beyond. The centerline of the obstruction clearance area may curve at a radius of not less than 4,000 feet, but the last 1,500 feet to the touchdown point must be straight in. Stopways are not usually considered, and clearways may not be considered, as available landing areas.
TransMach
Thanks for that. That is very clear and leaves nothing to interpretation. I wish we could have that info provided to us on other regulations!
135 landing distance
This is one of the most misunderstood aspects in 135 flying. Everyone thinks you factor the landing distance given in your AFM. Actually you factor the runway.
Example:5000ft rwy X .60=3000ft required. If your AFM landing distance is 3000 or less you meet the 60% rule. Most people look at the landing distance and multiply it by 1.6.
Assuming in this example that your AFM says the landing distance is actually 3000. You would meet the 60% requirement. Where most people go wrong is that the take 3000 X 1.6 = 4800ft. They assume this is the landing distance required (actually it is the minimum runway required if your actual landing distance is 3000ft). They then look at 5000ft runway and quickly conclude that 4800 is much greater than 60% and they say they cannot use the the 5000 ft runway.
Every time I go to FSI they misinform all the 135 guys. You always factor the runway, not the landing distance.
FLY.8,
I understand what you are saying, but I do it a slightly different way. I figure out how much the aircraft will weigh upon landing and then find out my actual landing distance based on the temperature and field elevation. Let's say that number is 3000' (to keep with your same numbers). I take 3000' and divide by 0.6 and get 5000' of runway as a result. This means I need at least a 5000' runway to depart for my destination airport.
Either way you do it, you get 5000' as the minimum runway needed. It seems like your way could take some trial and error though to find out if your destination airport has enough runway. Just my $0.02 worth.
the 80% rule is operator specific.....but to figure any of them out divide the required by .6 or .8 like stated above. for wet runways, take the AFM number multiply by 1.15 then divide by .6 or .8.
60%
If you take your AFM landing dist. X 1.67 or 1.91 (wet) you will have the req. r/w length.
Excel'n said:
Starcheckdriver is correct. Required runway length in the AFM landing distance divided by .6
Excel'n said:
Dividing something by .6 is the same as multiplying it by 1.67 (rounded) 1/.6=1.67
It may be the case, but the division is the correct way to do it. 0.6 comes from the FARs that state 60%. 60% is 60 out of 100 or 6/10 or 0.6. Multiplying by 1.67 is not quite the same, and yields a slightly higher number than dividing by 0.6
The correction factors are "not" cumulative as I understand it. While, of course, it is only being wise to consider the wet landing distance. It would not preclude you from taking off if the additional 15 percent is what puts you over the limit. The wet runway factor need only to be figured into the AFM landing distance.
Take Care,
I'm not quite sure I quite understand what you mean by that. The way I read it, 135.385(d) requires that 115% of the factored dry distance be available in order to take off a turbojet airplane for the planned destination with a wet/slippery runway unless the AFM has an approved procedure to shorten the wet landing distance. Eligible on demand operators are excepted in accordance with their OpSpecs. In any case, you may also take off if a suitable alternate airport meeting all requirements is selected and available.
(d) Unless, based on a showing of actual operating landing techniques on wet runways, a shorter landing distance (but never less than that required by paragraph (b) of this section) has been approved for a specific type and model airplane and included in the Airplane Flight Manual, no person may take off a turbojet airplane when the appropriate weather reports or forecasts, or any combination of them, indicate that the runways at the destination airport may be wet or slippery at the estimated time of arrival unless the effective runway length at the destination airport is at least 115 percent of the runway length required under paragraph (b) of this section.
(b) Except as provided in paragraph (c), (d), (e), or (f) of this section, no person operating a turbine engine powered large transport category airplane may take off that airplane unless its weight on arrival, allowing for normal consumption of fuel and oil in flight (in accordance with the landing distance in the Airplane Flight Manual for the elevation of the destination airport and the wind conditions expected there at the time of landing), would allow a full stop landing at the intended destination airport within 60 percent of the effective length of each runway described below from a point 50 feet above the intersection of the obstruction clearance plane and the runway. For the purpose of determining the allowable landing weight at the destination airport the following is assumed:
So assuming no AFM procedure allows a shorter distance to be used, it appears that you need to be able to land in 60% of the effective runway length as calculated by the above method for a dry runway and 115% of the factored dry distance if wet or slippery. If conditions change enroute, you may still land if the unfactored dry or wet/slippery (as applicable) AFM landing distance is available.
Best,
I do see your point. It does say for (taking off) that you must have 115 percent of the effective landing distance required by section (b), the 60 percent rule, when it is wet or slippery. They make it easy don't they.
I stand corrected - I think....
Thanks,
They sure don't!
I don't expect that to change anytime soon either. Working through the questions that come up on here is a great exercise for all of us. Nobody can know or remember it all and then properly apply it in the real world. We'll keep trying though!
Best,
just to bring this dead horse back to life...
If I'm flying to a wet rwy, and the dry landing distance is 3000ft, I multiply that by 15%, giving me 3450.
I then divide 3450 by .6 which comes to 5750. That is the required distance of the runway for me to takeoff.... Is that the correct method of going through that senario?
Be careful.....
Effective landing length off of a visual approach and effective landing length (usuable landing length) off of an ILS approach are two very different things.
If you are flying 135 into say, Atlanta-Peachtree. An ILS on 20L will yield you a very much shorter usuable landing length than that off a visual approach. If you are flying an ILS you must apply that 60% rule or 80% if using some form of runway analysis to the shorter length landing off the ILS. The full runway is not available and this will bite heavier jet operators in the rear if you get ramped.
fyi....
60% Planning / AFM for Landing
135.385 provides "Flight Planning" requirements. Once airborne the AFM (91) numbers provide actual runway length requirements. This is the short, simple and accurate explanation.
AA Order 8400 – Air Transportation Operations Inspector’s Handbook has been replaced by Flight Standards Information Management System (FSIMS). The link is provided below.
http://fsims.faa.gov/
http://fsims.faa.gov/PICResults.aspx?mode=Search&q=aircraft+performance+and+computation+rules&kw=aircraft+performance+and+computation+rules&status=a&syn=1&sort=0&
[FONT=&quot]E.[/FONT] Application of Flight Handbook Performance Limits. Many of the requirements of Subparts I of part 121 and part 135 apply only until the aircraft takes off from the departure point. Other requirements from these subparts apply at all times as do the AFM limitations. For example,§§ 121.195 and 135.385 prohibit a large, turbine airplane from takeoff unless, allowing for en route fuel burn, the airplane will be capable of landing on 60 percent of the available runway at the planned destination. The regulations do not, however, prohibit the airplane from landing at the destination when, upon arrival, conditions have changed and more than 60 percent of the runway is required. In this case, the airplane must only be able to land on the effective runway length as shown in the flight manual performance data.
FAR 135.385 + FAA Order 8900.1
Corp Pilot, your right. When I answered this thread in June 2006 (nearly 2 years ago) 8900.1 didn't exist.
The good news is that 8900.1 is a vast improvement over the 8400 Order for the FAA employee who is to apply the rules. I've used 8900.1 many times since it's publication to support exactly what we have been doing all along and my FAA POI goes right along with it (like he should).
Cheers!
TransMach
So after two additional years, do we agree yet that 1/.6 = 1X1.67? OK, for starcheckdriver, that's actually 1.66666666666666666 etc.
Example:5000ft rwy X .60=3000ft required. If your AFM landing distance is 3000 or less you meet the 60% rule. Most people look at the landing distance and multiply it by 1.6. end quote}
In this example, 8900.1 gives an example on how to factor in th 60%.
4)Runway conditions (including contamination). Runway features, such as slope and surface composition, can cause the actual landing distance to be longer than the calculated landing distance. Wet or slippery runways may preclude reductions from being taken and, in fact, require 115 percent of the distance derived from calculations, whether a reduction was used or not. This distance is calculated by increasing the distance required under dry conditions by an additional 15 percent (i.e., if Aircraft Flight Manual (AFM) data shows the actual landing distance will be 2,000 feet, the effective runway length required is 3,334 feet using 60 percent in this example. If the runway is expected to be wet or slippery upon arrival, the effective runway length required is 3,834 feet). Braking action always impacts the landing distance required as it deteriorates. Always consider the most current braking action report and the likelihood of an update prior to the flight’s arrival at a particular airport.
In their example, they factor the AFM numbers and not the runway. This is the way I have been doing this for years.
By using this example, you would not divide the runway legnth by .6, but the AFM numbers.
Who is correct?
I've always factored the AFM numbers as well, not the runway (divide the AFM number by .6).
And from the example in 8900.1, it looks like that is the correct way to do it.
Starcheckdriver is correct..
Gee, that quote is the same line I used for my first post to this thread. Mobie suggested and I clarified the simple mathematical fact that 'one divided by point six is the same as one times one point six seven' (rounded of course). This must be one of those "new math" anomalies.
osy007
"And how do you even find a thread that began 2 years ago. Talk about digging through some 'ol shee-ite."
Answer- On 5/24/2008 CFIIer and 5/25/2008 B737Dvr replied to post bringing it to the top of the list. Kinda thought you might figure that one out by yourself. Guess I was wrong.
osy007
"Took him 2 years to find the answer that someone else already answered...lol"
Comment- Guess I missed the previous post (and I am sure you can point it out) which answered the original question by locating the FAA reference which in part states "the airplane must only be able to land on the effective runway length as shown in the flight manual performance data."
Original question posted by Star Checker (2 years ago)
135.385 in all its glory refers to planning and does not prohibit you from landing with less than 60%/80% in accordance with FSIMs. My post of 5/26/2008 provides not my opinion, but the facts as documented by the FAA.
I apologize to those that I have confused or caused undue stress.
135 Landing Distances
Here is my 02 cents:
Pre-takeoff planning:
AFM numbers X1.67 (per SAFO below)
Then multiply by the following Factors:
Runway Condition Reported Braking
Action
Factor to apply to
(factored) dry runway
landing distance*
Wet Runway, Dry Snow Good 0.9
Packed or Compacted Snow Fair/Medium 1.2
Wet snow, slush, standing water, ice Poor 1.6
Wet ice Nil Landing is prohibited
Table 2. Multiplication factors to apply to the factored dry runway landing distances when
the data for the specified runway condition are unavailable.
* The factored dry runway landing distances for use with Table 2 must be based on landing
within a distance of 60% of the effective length of the runway, even for operations where the
preflight planning (factored) dry runway landing distances are based on landing within a distance
other than 60% of the effective length of the runway (e.g., certain operations under part 135 and
subpart K of par t91). [To use unfactored dry runway landing distances, first multiply the
unfactored dry runway landing distance by 1.667 to get the factored dry runway landing distance
before entering Table 2 above.(table did not paste correctly)
Upon Arrival use AFM numbers X 1.15 if contaminated (under Part 135, the FAA does not differentiate between contaminants, nice!, however in the 8900 they mention if contaminated data exists (even non-approved) you "should" use it. Usually the contaminated data in AFM'S is every thing other than WET, ie. compacted snow, wet snow, standing water. So if it is only wet use the AFM landing distance X 1.15. This is certainly not a black and white subject. There is a lot of information out there, ie 8900, SAFO's, REGS. I always use the most conservative number. So if ever in a court of law, I can fully explain my decision to land on a particular runway. Good luck out there guy's!!!
If contaminated then multiply by 1.15
If runway data is not available use the following factors:
Action
Factor to apply to
landing distance*
