For my CubCrafters Carbon Cub FX-3 I started with a NOCO Genius 5 to maintain the starter battery which can be plugged into the 12V receptacle under the dash (or rear seat if you have that option). I later switched to the Odyssey charger and have to say I believe it is a better charger/maintainer for the battery. I did install the pigtail on the battery which is how I connect the charger to the battery otherwise you'd have to connect directly to the battery by tilting the front seat forward (not ideal).
Amazon product ASIN B01CGJH9PG
Here is the NOCO Genius 5 I started with but no longer use:
Amazon product ASIN B07W8KJH44
You will need the 12V adapter:
Amazon product ASIN B004LWWNI0
