I learned of the Aithre shield CO detector that integrates in the G3X from the CubCrafters community and had one installed in my 2021 CubCrafters FX-3. Nothing alarming and it seemed to work well. Then came along my 2023 CubCrafters FX-3 and right off the bat I'm seeing very high CO readings and can't figure it out. Is it a bad Aithre? Was the prior one bad? Is it in a different location? What is the deal. I'm getting red alerts and thought it was just something to ignore. WRONG.
During my landing light upgrade saga I had the GDU out and saw the Aithre was located in the exact same location. As I had silicone caulk out for the landing light covers I figured I'll seal the gear leg area as I know from @turbopilot he raised a concern that this was a path for CO getting into the cockpit. Today I flew for the first time since sealing these areas and it seems the holes are larger than the last plane and sure enough PROBLEM SOLVED! I was not in the red at all today and this made the difference. Now keep in mind I have a cargo pod and that's going to make matters a little worse acting as a baffle for the exhaust which will presumably force it into these gaps.
I recommend everyone seal these openings belly pod or not. CO is poison and the factory should be sealing these gaps as well for the protection of the pilots. Don't mess with CO in your home or plane!
Shield EX 2.0 Behind-the-Panel CO Detector - With iOS App - Black
Experimental Aircraft Only: The Aithre Shield EX 2.0 is the first behind-the-panel mounted carbon monoxide detector that puts ultra-sensitive CO readings directly on your iOS device, Dynon SkyView, Garmin G3X, and Advanced Flight Avionics. Features simple 3-wire installation, a small footprint...
aithreaviation.com
