Okies...I know this has been addressed a lot recently, but humor me...
So you're rolling down the runway and you've determined (using performance charts, FMS, your FO's forehead, whatever) that V1 is A knots, Vr is B knots and V2 is C knots.
So you hit V1 and your airplane is operating normal so (obviously) you're going. You now are at Vr so you rotate and accellerate to V2.
The way I understand it is like this.
V1 is decision speed - you decide wether or not you can safely takeoff. This could be affected by gross weight, accel. stop/accel. go distance, density altitude, runway length, wind speed and direction, presence of a stopway...(anything else?). Basically you figure out before you even start up what your V1 is.
How am I doing so far?
Vr is the speed which you rotate (duh) - I have no clue what this is based on which is where my questions will come from later...
V2 is takeoff safety speed - From what I understand this is the speed which (should an engine failure occur after takeoff) you need to accellerate to so that you can safely enter the pattern (shoot an approach - whatever) and set 'er down.
Okay...so here's the question(s)
1. I know sometimes they are the same, but why isn't V1 always equal to Vr? Like...if this is the speed you have to decide wether or not you can takeoff, shouldn't you be rotating at this time?
I guess I realize that if you had a 40,000' runway, V1 would equal (or even exceed - which by definition it couldn't since if you've rotated you've already decided, right?) Vr because you would have enormously more time to decide wether or not you would have to rotate or not and thus would be airborn well before you absolutely had to decide to abort the takeoff if you lost an engine. (and I realize that the example is distorted with a 7+ mile runway).
But my confusion stems from the opposite example. Say you had a 1,000' runway and you had to bust out a max performance short field takeoff. Your V1 would be amazingly shorter to give you adequite chance to stop the aricraft before the end of the runway, correct?
In this example, you advance the power, release the brakes, accellerate down the runway and reach V1 (at some point) and decide you can continue the takeoff. Well on a 1,000' runway (again extremely distorted from real world to make a point) you would reach V1 significantly before you could rotate, correct? Or does the fact that it is a max performance takeoff reduce the rotate speed so much as to close the gap?
2. What exactly does happen if you lose an engine between V1 and Vr? Obviously you're going airborn (since you've blown by V1), but does that slow the accelleration down enough to make you sweat waiting for Vr to show up? How much shorter does it make the runway seem? Enough to make you nervous or is that also factored into the preflight planning of runway length, gross weight, wind speed and direction, etc.?
3. Exactly what does go into figuring out Vr as opposed to V1?
I think thats it for now. Thanks for the help!
-mini
-mini
