Hey Guys.
I'm having trouble getting a complete explaination of what to do in this situation. In fact, from discussing this with other pilots, I'm not sure whether I violated an FAR or not.
Flying south, VFR, towards a busy Class D airport, one must fly around (takes awhile), above (not practical), or through Class B airspace for an active Military base. I optioned to get the Class B clearence directly from the base for the transition. Prior to exiting the Class B I was told to contact the Class D tower. I did this, but I was told "aircraft calling, standby." My understanding is that I have not heard my N# and therefore am not in contact with the controlling agency. At the time, I believed that I was "stuck". I was still technically on a Class B clearence until I left the airspace at which time I would be in the Class D. The problem is that at the altitude assigned by the Class B controller, I would be below the ceiling of the Class D. So, I passed from the B to D without establishing contact. I then immediately climbed to the ceiling of the Class D. The tower called me back and directed me in to the flow of traffic. The tower was busy, but nonetheless did not question my actions. Was I legal? What should I have done?
Since the Class B controller had given me " mid-field transition at 2600 msl", could I have turned 360s above the field until establishing contact with the class D controller? Can I "inform" the Class B controller of what I need to do, or must I get a clearence from him? Keep in mind that I wasn't assigned a heading.
If I were talking to an approach controller, could I have assumed that I was clear in to class D per a handoff? Is it right to assume that I was handed off in this case and that is why I was okay to enter the class D?
Was I stuck between two violations? What would you guys do?
Thanks for the input.
