1. Steep Spirals - When doing Steep Spirals, my CFI will oftenhave me turn with a large amount of bank when turning from "upwind" to"base" (if that makes sense). I'm having a hard time explainingto him that when I do that, the spot that I'm spiraling around goescompletely under the plane. My feelings are that the wind ispushing me over the object so I should: 1. Be wings level (orvery little bank) on "upwind" and 2. Crab into the wind on the"base" leg. Then I can turn "downwind" and "crosswind" with a lotof bank to keep the point over me.
Thoughts? Opinions? Tips?
2. Lazy Eights - Having a hard time getting the left ones towork. I think I may be trying to pitch up a bit much (just foundout I don't have to get it to Vso+5 for these). I guess I'm justnot putting in the right control inputs at the right times. Perhaps the nose should be "slicing" through the horizon at 45* insteadof 90*, but I'm told to keep pitching and banking until 90*.
3. Chandelles - Not quite getting it around to 180* on the rollout. It's still to PTS (usually 175* +/-5*) but I'm not justtrying to "qualify" here, I want to "perform". Perhaps a bit toomuch pitch up attitude too quickly? You're supposed to alterpitch in the first 90* and then bank angle in the second 90* but I'veheard that some get away with banking to 30*, pitching up to around 12*and then just riding it out.
4. Stalls - I need to be proficient at doing power on/offstalls. When I perform them, my first reaction is "oh, break thestall" so forward I push and the nose drops below the horizon. Obviously, my CFI is not happy since he wants the nose lowered only tothe horizon. My only concern with that is when I tried it the twotimes, we went into secondary stalls. Not something I want to doon the check ride.
5. Power Off 180* Accuracy Approaches - Okay, so I haven't donenot one with a CFI, but here's what I've been working on. Abeamthe 1000' marks on the runway (my point), I apply carb heat, close thethrottle, request the short approach, maintain altitude while trimmingfor best glide and then put it down. I'm not saying that it's theprettiest pattern in the world, but I can't find a PTS requirement fora "pattern". I've been told by a check airman that all I need todo is get it on the runway at or 200' beyond the aiming point whilemaintaining altitude initially to trim for best glide. So far,I've been doing this in my own little "I haven't been 'taught' theproper way" way. is this correct?
6. System Knowldege - Okay, so I've heard differing opinions onthis. A few opinions are that I will have to diagram the systems(electrical, hydraulic, fuel, etc.) for the airplanes that I'll beusing (C152 and C172RG). Doing the fuel system is easy since theyare easy systems, but I'm having a hard time memorizing the diagram forthe electrical system and hydraulic system. I can tell you allabout them, but I can't seem to be able to draw them out. Myfeelings on this are: It's in the book, I know how it works, if Iwant to build one, I'll look it up. The other opinions I havegotten are "if you can explain it, that's all that matters". I'dlike to be as prepared as possible going in to stage 3 (All C172RGFlights) so I don't bone this stage 2 Oral (which from what Iunderstand will be tougher than the actual check ride).
7. This is kind of a CFI check ride thing, but here goes. We were told (students) by the Examiner doing our CFI rides (when weget there) that if we don't use an actual checklist before landing(like...doing a flow, GUMPPSS, etc.) and stop once clear of the runwayto do a checklist, we will bust the checkride (he doesn't like hotplanes). Okay, no problem, but unless tower gives me instructionsto taxi to the ramp as/before I leave the runway, I always stop tocontact ground once clear. While I'm contacting ground I gothrough getting the lights, transponder, flaps, etc. I don'tnecessarily use a paper checklist, but I do hit all of theitems on the checklist (I have another flow for that). Is thereany reason to think that such a scenario will cause a bust?
8. Touch and Gos Complex - I don't like the idea of doing TnGs ina complex airplane. I've heard lots of stories of wellintentioned students/instructors reaching for flaps to bring them upand "oh sh*t that's the gear"ing it. I can't find a PTSrequirement for touch and goes for either the Commercial or CFI checkride. Any reason to think the examiner will bust me for wantingto be safe, clear the runway, do the flaps once clear and I have timeto THINK?
Thanks all for any help you can provide. I really appreciate it.
-mini
-mini
