hotwings402
- Apr 3, 2005
threegreen said:what kind of airplane were you in. what was he in?
good thing you made a post about this on flightinfo.
zugzug said:Why didn't you just land and ask him/her.
Sure, if nobody is in the pattern or you can land without cutting someone off.dhc8fo
Although more details are in order, you need to know that there is nothing wrong with a straight in approach.
If you were on final and he was in the pattern.. Chances are he was lower and closer than you and has the RIGHT OF WAY!dhc8fo
I was recently a victim of this and the guy on downwind turned base with his student RIGHT in front of me inside of a 2 mile final at 700 feet. I went around.
dhc8fo
Needless to say that guy is on my pooperlist and will now be blacklisted by others who respect me and my opinions.
dhc8fo said:Although more details are in order, you need to know that there is nothing wrong with a straight in approach.
I found out who he was and had a little discussion with him....it was his opinion that since he had been in the pattern all day long that my calls (from 10 miles out) and my entry didn't matter and he was willing to risk some lives to make a point. Needless to say that guy is on my pooperlist and will now be blacklisted by others who respect me and my opinions.
Aviation is a small community. Give a little professional courtesy now and then and it will also be given back to you. Everyone makes mistakes, but it is not worth it to see who wang is bigger when there are lives at risk.
hotwings402 said:Careless and reckless you were not using a recommended or approved pattern entry and if a midair occured you would have been cited it for not following a recommend procedure as per the aim at some point the other guy in the pattern was lower than you and had right of way how came first the jerk making a straight in or the guy following the recommended procedure flying a PATTERN. geez
hotwings402 said:He did a straight in to final and cut us off when we were on base
dhc8fo said:OK, I THINK I understood some of that one....
ohhhh contrare mon frare (in my best french accent).... NOWHERE in the AIM or the regs does it say that pattern entries are REQUIRED (and I have never heard of an "approved" pattern. What it does say is that the person at the lower altitude in the pattern does have the right of way but that he cannot use that as a means to cut someone off (which is what happened in MY case).
No, I would not have been cited in this case since the other four people in the pattern heard and saw everything and I was not in the wrong (and if it makes you feel better, one was an examiner on the field who I also talked to about this).
And as far as my "list" goes... you just wait. Once you get a little more experience, you will see just how small this community is. If you guys go around cutting off your brethren in the pattern just because you feel like it when he wants to make a straight in approach, word will spread that you are a dick and you won't be getting a lot of calls to sit right seat....
8inMan said:It would have been a good thing to teach your student that this type of thing happens regularly at airports all over the country. You just talk to the a/c doing the straight in and coordinate with him. Extend your downwind a little if you have to. Its common courtesy and common practice. Don't tell your student that the pilot of the larger a/c is a jerk. You're just giving that student a foundation for future air rage.
You may want to rethink you thinking!hotwings402 said:Careless and reckless you were not using a recommended or approved pattern entry and if a midair occured you would have been cited it for not following a recommend procedure as per the aim at some point the other guy in the pattern was lower than you and had right of way how came first the jerk making a straight in or the guy following the recommended procedure flying a PATTERN. geez
You may also want to rethink your attitude. The other guy a "jerk" for "cutting you off", you've been doing pattern work for over an hour, how about extending some common courtesy and simply extending you downwind a little.hotwings402 said:guy in the pattern was lower than you and had right of way how came first the jerk making a straight in or the guy following the recommended procedure flying a PATTERN. geez
