FDJ2,
Take a second look at what I said, please. I did NOT say that another certificate allows circumvention of your Scope clause. That is not
my premise at all. I said that
IF this were so, it would render your scope impotent, which it would. The premise was that of the person to whom I responded.
If his premise is not accurate, then it follows there is no difference between the Dornier being operated by ACA (because they will have Airbus aircraft) or Skyway because Midwest has Douglas aircraft. The only "difference" between the two is the referenced certificate.
You are correct about the language of the Delta PWA. My point is really quite simple. The language itself is useless because it is not legally enforceable unless the offender, in this case ACA or SKY, chooses to endorse the provisions of your PWA via language in their contract with Delta. Most airlines, even regional airlines, have not yet been desperate enough to do that.
Why on earth would any viable business give the Delta pilots the right to dictate whom it will do business with or what its business plan should be?
You are attempting to do the same thing that USAirways pilots tried to do. The result was Freedom and later Republic, both of which did circumvent the Scope clause. That is because both Mesa Air Group management and Chautauqua management didn't have the guts to tell USAG where to go and found the way around it by creating alter egos. In turn, the union that created the mess wound up by forcing the Mesa pilots into an abomination of a contract, plus both Mesa and CHQ pilots abidicated their seniority via Jets for Jobs in an effort to regain control of the alter egos.
Management knows what it is doing with this issue, and the labor union (ALPA) is engaged in illegal practices against its own members.
In the ACA scenario the Company (Delta) is not enforcing your Scope. It is acting on the basis of its own contract with ACA and the relevant escape clause (termination without cause).
This kind of garbage scope is exactly why your company wound up having to buy Comair and it is why ACA told UAL to go to he!!. UAL couldn't buy ACA because they are bankrupt. At the time Delta had lots of money and it could and did buy Comair. Otherwise, Comair management would have done exactly what ACA management did vis a vis UAL, i.e., told you to pound sand.
There was no six month escape clause in Comair's contract with Delta. The ten year contract was expiring and CMR would not accept Delta's terms for a renewal, nor would Delta accept Comair's. That left two options, buy us or watch us continue on our own way and lose your lift. It is obvious which course Delta decided to take.
If you do not believe that Delta cutting a deal with Skyway bypasses your scope then please tell me why. Why does that transaction comply with your scope clause if the ACA transaction does not? What makes it "different"?
I would also like you to tell me why the CHQ deal with UAL, which will result in the operation of aircraft with more than 70-seats by CHQ, does not violate your scope. Tell me also what you intend to do about it. Are you going to tell Delta that it has to cancel its contract with Chautauqa? Would you like to take bets on how soon they'll do that? There are multiple certificates at Chautauqua too (their own plus Republic), but both of those carriers will soon be operating aircraft with more than 70-seats. What are the Delta pilots going to do about it?
To the Skyway folks --- Please do not think that I am against your making a deal with Delta. I am not opposed, hope you get the contract and wish you well.
FDJ2 said:
Surplus, your premise is wrong from the start, since for the purposes of the Delta PWA a "domestic air carrier" is defined in 49 U.S.C. Section 40102(a)(2), not by the FAA and not by which certificate it flies under. Since much of your argument is based on this false premise your point that scope is impotent and useless because it can be avoided by initiating multiple certificates is incorrect.
You are right that the DAL PWA is not binding on ACA, but it is binding on DAL, therefore DAL must conduct its dealings in accordance with the DAL PWA and it is binding and lawful.
